In my panel I'm using nginx. Now want to move apache. After uninstall nginx tried installing apache 2.4 but after finished the task its showing that apache not installed. Again tried to install and again not succesffully installed. Also there not showed any error.
Please solve it.
Thanks
Problem to Install Apache Server
Hello, please check the installation log to see what caused the installation to fail.
Hello, Ubuntu 16 has officially stopped maintenance.
aaPanel_Kern So what need to do now?
It is recommended to replace the system
aaPanel_Kern If I give you the tarminal password. Can you please help?
Hello, it is recommended to do a server snapshot backup before operation to avoid other errors.
It is recommended to do it yourself
aaPanel_Kern just do this step. use ubuntu 20 or 22 or LTS version.
