mehulsbhatt Hi I have installed aaPanel successfully and trying to enable Nginx Firewall Module but i getting pop up message even i have enabled Nginx Firewall When i am trying to enable getting below popup [ Please advice Regards, Mehulkumar Bhatt
TheWormsUnited mehulsbhatt perhaps you found a bug in the new release. Maybe @aaPanel_Jose can have a look at it
aaPanel_Jose mehulsbhatt emmm, the firewall in the website list corresponds to another firewall with advanced functions, and the free Nginx firewall is not associated with this You just ignore it. . Or I can cancel this button in the next version if it annoys you
mehulsbhatt Thanks for your reply, i personally suggest that you should remove the BUTTON from UI to avoid misunderstanding. Again, aaPanel is grate project. Well done Regards, Mehulkumar Bhatt
