hi everyone,
I can't create an SSL certificate with Let's Encrypt.
The problem occurred while I was testing denying access in the web configuration. I added the txt prefix and applied it to the main path /. Then I removed it and now there is no limitation at all. I deduce that this was the cause of the problem because only the sites where I applied that configuration were affected.
After those changes (which were removed) the websites with PHP have reverted to static web and the SSL certificate has stopped working, which is not reflected in the aaPanel because the certificate files are still in the correct folder.
Now, when I try to set a PHP version, an unknown error appears with no information, and when I try to redo the certificate, an error appears which I copy below:
The account has more than 5 failed orders within 1 hour, please wait 1 hour and try again!
Verify domain name:xxxxxxxxxxx.com
Verify URL:Click to view
Verify content:x_sLPkY300U6nioMJrUM9FpH4cT36S_REr_1PI2Tlkk
Error code:91.107.253.94: Fetching http://xxxxxxxxxxx.com/.well-known/acme-challenge/x_sLPkY300U6nioMJrUM9FpH4cT36S_REr_1PI2Tlkk: Connection refused
Verify results: Verify failed
On some sites I've been correcting the problem by waiting a few hours and then insisting again, but it doesn't happen with the last of the affected sites. And even if I manage to correct the problem in the next few hours, I would like to know what could have happened.
Any ideas?
