aaPanel_Kern avijit hello you can change panel settings replace panel 404 error You can open the 404 error on the website and modify the 404.html file under the site, pay attention to the second 404 panel settings:
aaP_hk2263247 aaPanel_Kern Can you tell me in details please i'm faceing the same issue how to solve it panel 404 from my wordpress website
klaus avijit You can use the file manager from aapanel, www/server/panel/BTpanel/templates/default here you will find all the layouts(including error pages) in html.
aaPanel_Kern avijit The main configuration file of nginx is at: /www/server/nginx/conf/nginx.conf You can also find nginx view configuration files in the app store The panel's 404 interface does not support changes
