Ubuntu 18.04
i don't know why cpu load to high, anyone can help me? how can i solve it
    SkyLastn Because you use windows and I presume is WSL because I can't see the task manager so yeah pretty much that is.
    SkyLastn
    Hello, try to execute the command to repair the panel: bt 16 Can it be solved?
    At the same time, we have not done compatibility on wsl
    already solved bro,
    the problem because my pc background running some task, that couse my Virtual machine cpu always full
    oh no , it happend again,
    how to see what command/service that make it full load bro? so that i can turn off
    limit php-fm
    limit max child
    if you using apache
    that's will be works
    but if you use OLS, try to throttle client per ip
    it works good
    i already limit max child, is it the best configuration on apache?
    there's no best conf...
    but there's optimal conf
    and it's depend of your spec
