I have these outputs
0K . 100% 349M=0s
2023-04-20 07:12:56 (349 MB/s) - '/www/server/nginx/conf/enable-php-56-wpfastcgi.conf' saved [1327/1327]
--2023-04-20 07:12:56-- https://jp1-node.bt.cn/install/wordpress_conf/nginx/enable-php-70-wpfastcgi.conf
Resolving jp1-node.bt.cn (jp1-node.bt.cn)... 45.76.53.20
Connecting to jp1-node.bt.cn (jp1-node.bt.cn)|45.76.53.20|:443... connected.
Length: 1327 (1.3K) [application/octet-stream]
Saving to: '/www/server/nginx/conf/enable-php-70-wpfastcgi.conf'
0K . 100% 316M=0s
2023-04-20 07:13:01 (316 MB/s) - '/www/server/nginx/conf/enable-php-70-wpfastcgi.conf' saved [1327/1327]
--2023-04-20 07:13:01-- https://jp1-node.bt.cn/install/wordpress_conf/nginx/enable-php-71-wpfastcgi.conf
Saving to: '/www/server/nginx/conf/enable-php-71-wpfastcgi.conf'
0K . 100% 282M=0s
2023-04-20 07:13:01 (282 MB/s) - '/www/server/nginx/conf/enable-php-71-wpfastcgi.conf' saved [1327/1327]
--2023-04-20 07:13:01-- https://jp1-node.bt.cn/install/wordpress_conf/nginx/enable-php-72-wpfastcgi.conf
Saving to: '/www/server/nginx/conf/enable-php-72-wpfastcgi.conf'
0K . 100% 254M=0s
2023-04-20 07:13:06 (254 MB/s) - '/www/server/nginx/conf/enable-php-72-wpfastcgi.conf' saved [1327/1327]
--2023-04-20 07:13:06-- https://jp1-node.bt.cn/install/wordpress_conf/nginx/enable-php-73-wpfastcgi.conf
Saving to: '/www/server/nginx/conf/enable-php-73-wpfastcgi.conf'
0K . 100% 527M=0s
2023-04-20 07:13:07 (527 MB/s) - '/www/server/nginx/conf/enable-php-73-wpfastcgi.conf' saved [1327/1327]
--2023-04-20 07:13:07-- https://jp1-node.bt.cn/install/wordpress_conf/nginx/enable-php-74-wpfastcgi.conf
Saving to: '/www/server/nginx/conf/enable-php-74-wpfastcgi.conf'
0K . 100% 478M=0s
2023-04-20 07:13:12 (478 MB/s) - '/www/server/nginx/conf/enable-php-74-wpfastcgi.conf' saved [1327/1327]
--2023-04-20 07:13:12-- https://jp1-node.bt.cn/install/wordpress_conf/nginx/enable-php-75-wpfastcgi.conf
HTTP request sent, awaiting response... 404 Not Found
2023-04-20 07:13:12 ERROR 404: Not Found.
--2023-04-20 07:13:12-- https://jp1-node.bt.cn/install/wordpress_conf/nginx/enable-php-80-wpfastcgi.conf
Saving to: '/www/server/nginx/conf/enable-php-80-wpfastcgi.conf'
0K . 100% 287M=0s
2023-04-20 07:13:18 (287 MB/s) - '/www/server/nginx/conf/enable-php-80-wpfastcgi.conf' saved [1327/1327]
--2023-04-20 07:13:18-- https://jp1-node.bt.cn/install/wordpress_conf/nginx/enable-php-81-wpfastcgi.conf
Saving to: '/www/server/nginx/conf/enable-php-81-wpfastcgi.conf'
0K . 100% 476M=0s
2023-04-20 07:13:18 (476 MB/s) - '/www/server/nginx/conf/enable-php-81-wpfastcgi.conf' saved [1327/1327]
--2023-04-20 07:13:18-- https://jp1-node.bt.cn/init/nginx.init
Resolving jp1-node.bt.cn (jp1-node.bt.cn)... failed: Connection timed out.
wget: unable to resolve host address 'jp1-node.bt.cn'
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_US:en",
LC_ALL = (unset),
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
|-Successify ---Script execution completed---
