aaP_ibrahimo_tm Hello, I have installed aa Panel on Server from Hetzner, the server Storge is 2 x 512 GB, But after setup aa Panel I only see one hard drive, What can I do to make the panel recognize 2 hard drives?
aaPanel_Kern aaP_ibrahimo_tm Hello, the hard disk on the panel is read from the system, please check whether the relevant hard disk is mounted in the system It is recommended to refer to the tutorial operation of the server provider. or consult your server provider
aaP_hareeshnarayan1982 aaP_ibrahimo_tm You should actually configure atleast raid 0, before using for data redundancy. And also if you don't want that, you should mount the second drive as a persistent volume.
