aaP_hakimluk0154 hey help me i can't access aapanel after i did domain setup with error ERR_CONNECTION_TIMED_OUT i have tried bt 22, bt 13 but still can't, is there any way to solve it?
aaPanel_Kern Hello, please check whether there is an error in the result of executing the bt 12 command? Check if the bt service is running? bt status Also check Access panel using full link? bt 14 It is recommended to provide a screenshot aaP_hakimluk0154
aaP_hakimluk0154 I just tried to reinstall and setup the same domain and it still has an error, I try to follow the results like this]
aaPanel_Kern aaP_hakimluk0154 If the domain name is set, only the domain name can be used for access. ip forbidden access The set domain cannot be a proxy, and the A record of the domain must point to the server's ip Cancel domain: bt 12
aaP_hakimluk0154 ok it worked for me, i turned off the proxy on my cloudflare, but after that it shows error (your-connection-is-not-private)
aaPanel_Kern aaP_hakimluk0154 Refer to this tutorial Using a domain name requires a Let's Encrypt certificate https://www.aapanel.com/forum/d/15210-aapanel-enable-panel-ssl-use-self-signed-certificate-browser-add-secure How to bind domain? Create a subdomain in the domain name management website, which is specially used for the panel. The A record of the subdomain must point to the IP of the server, and proxy and CDN cannot be used Bind the subdomain to the panel settings. If the domain name is bound, only the domain name can be used to access the panel, and the use of ip to access the panel will be prohibited.
valuvesta This site can’t be reached. The web page at https://sub.mywebsite.com:7800/xyz might be temporarily down or it may have moved permanently to a new web address. ERR_CONNECTION_ABORTED I am getting this error after connecting to cloudflare. Sub domain is no cdn. I don't know why I cannot access my panel. Please do help
aaPanel_Kern Hello, what have you done? If the domain name is in CloudFlare, please do not enable the proxy. CloudFlare does not support port 7800. valuvesta
