aaP_raviranjanbodh try remove the dns records with domain. The domain provider is responsible for binding the domain to the IP, not you, you just need to specify your domain in the panel so that it is displayed.
You should have checked this at the stage when the provider informed you that you had a problem with dns.
In order to bind your domain, to your IP, contact domain support so that they attach a domain to it, on your side you only need to specify the domain, and not raise the DNS, especially when you are in this 0
