I have added the security certificate of Cloudflare (Origin Certificates) but (https) has not yet
SSL Panel
Hi, Origin Certificates is also not trusted by the browser. It is recommended to use Let's Encrypt or other certificates trusted by browsers
Do you have a tutorial on how to do this?
Please share with us. This is one of the things I most want to do on aapanel.
roniel
Turn off Panel SSL and turn it on again and select Let's Encrypt
Don't work it.
error:
"You need to bind the domain name to the panel before you can apply for the Lets Encrypt certificate."
How i can bind?
roniel
Follow the prompts to bind the subdomain to the panel settings. After binding the domain name, only the domain name can be used to access the panel, and the use of ip to access the panel will be prohibited.
The A record of the subdomain must point to the ip of the server, proxy and cdn cannot be used
Or use a self-signed certificate, the browser adds a trusted root certificate
https://www.aapanel.com/forum/d/15210-aapanel-enable-panel-ssl-use-self-signed-certificate-browser-add-secure
Thanks
