URL transformed to HTTPS due to an HSTS policy
--2023-08-10 13:54:21-- https://node.aapanel.com/install/public.sh
Resolving node.aapanel.com (node.aapanel.com)... 104.21.79.196, 172.67.171.7, 26 06:4700:3031::6815:4fc4, ...
Connecting to node.aapanel.com (node.aapanel.com)|104.21.79.196|:443... connecte d.
Length: 4377 (4.3K) [application/octet-stream]
Saving to: ‘/www/server/panel/install/public.sh’
/www/server/panel/i 100%[===================>] 4.27K --.-KB/s in 0s
2023-08-10 13:54:21 (59.9 MB/s) - ‘/www/server/panel/install/public.sh’ saved [4 377/4377]
selecting download node...
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
sudo is already the newest version (1.9.5p2-3+deb11u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
groupadd: group 'redis' already exists
useradd: user 'redis' already exists
E: Unable to locate package lsphp80-redis
E: Couldn't find any package by glob 'lsphp80-redis'
E: Couldn't find any package by regex 'lsphp80-*redis'
[OK] Send SIGUSR1 to 19157
php-8.0 not install, Plese select other version!
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_US:en",
LC_ALL = (unset),
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
--2023-08-10 13:54:38-- https://node.aapanel.com/tools/check.sh
Resolving node.aapanel.com (node.aapanel.com)... 172.67.171.7, 104.21.79.196, 2606:4700:3031::6815:4fc4, ...
Length: 565 [application/octet-stream]
Saving to: '/www/server/panel/install/check.sh'
/www/server/panel/install/chec 100%[=================================================>] 565 --.-KB/s in 0s
2023-08-10 13:54:38 (17.7 MB/s) - '/www/server/panel/install/check.sh' saved [565/565]
