I want to ask about the command to restart the node project using command, can you help me? I can understand your code above will check the status of the project, if it = 0 it will turn it back on. However, I have a Next js project and there are a few static files that are written to the public after a period of time, so I need to leave cron so that this project is restarted after adding the public files.
