zinedine_jidun aaPanel_Kern Hai, After we add certificate and private key to aaPanel in menu settings, ssl not working, https is not secure Do I have to restart aapanel first? Thank you
aaPanel_Kern zinedine_jidun Your certificate is a domain name certificate? If so please use the domain name to access the panel. The A record of the domain name must point to the server IP and cannot be a proxy At the same time, after replacing the certificate, you need to reopen the browser aaPanel enable Panel SSL https://www.aapanel.com/forum/d/15210-aapanel-enable-panel-ssl-use-self-signed-certificate-browser-add-secure
zinedine_jidun aaPanel_Kern Yes my certificate is a domain certificate, we access the panel with domain. We have our own .pfx, do we have to upload it to this directory /www/server/panel/ssl ?
aaPanel_Kern zinedine_jidun Copy and paste the content of the domain certificate file into the box of panel ssl according to key and Certificate pfx files need to be converted to crt It is recommended to use a self-signed certificate or directly use a domain name to apply for a certificate Self-signed certificate adding browser trust tutorial: https://www.aapanel.com/forum/d/15210-aapanel-enable-panel-ssl-use-self-signed-certificate-browser-add-secure
aaPanel_Kern zinedine_jidun You can try it, the certificate file also needs to be replaced, otherwise it cannot be verified
zinedine_jidun aaPanel_Kern If I replace all these files with my certificate files, will ssl work? and aapanel web secure is work?
aaPanel_Kern zinedine_jidun Hello, after backing up, try web security It depends on whether the replacement is successful and whether the replacement is correct
aaP_haroun03 "Can a sub domain be connected to the website's control panel, and how can this be done?"
aaPanel_Kern The A record of the subdomain name is resolved to the IP of the server, and you can use the subdomain name to access aapanel. Note that you cannot use a proxy aaP_haroun03
