done
Starting Bt-Tasks... failed
File "/www/server/panel/BT-Task", line 13, in <module>
import task
File "/www/server/panel/task.py", line 22, in <module>
from psutil import Process, pids, cpu_count, cpu_percent, net_io_counters, disk_io_counters, virtual_memory
ModuleNotFoundError: No module named 'psutil'
import task
EXECUTING
File "/www/server/panel/BT-Panel", line 10, in <module>
from gevent import monkey
ModuleNotFoundError: No module named 'gevent'
lrwxrwxrwx 1 root root 37 K-Ɔ 9 14:07 python -> /www/server/panel/pyenv/bin/python3.7
-rwx------ 2 root root 15373920 K-Ɔ 9 14:06 python3.7
---------------------- python3.7
lsattr: Operation not supported While reading flags on python
ERROR: The BT-Panel service startup failed.
I manage to install all the packges but I still didn't work
