UfukCH hello friends, I installed aa panel, but I couldn't do webmail, and I can't enter phpmyadmin panel, how is it done?
aaPanel_Kern UfukCH Hello, what version is your operating system? What information does the webmail prompt fail to install? What information does phpmyadmin fail to enter? Is phpmyadmin installed, and is the port used by the system firewall and the security group of the server provider open?
UfukCH aaPanel_Kern hello Ubuntu 20.04.6 LTS x86_64(Py3.7.9) I disabled the firewall with chmod 777 with phpmyadmin installed  I wonder if the user admin password is wrong
aaPanel_Kern chmod is a permission command, it is suggested that you give the error message. Whether the user information is correct will be displayed when logging in UfukCH
