-2024-05-08 17:50:25-- https://node.aapanel.com/install/0/docker_install_en.sh
Length: 16976 (17K) [application/octet-stream]
Saving to: ‘docker_install_en.sh’
0K .......... ...... 100% 115M=0s
2024-05-08 17:50:26 (115 MB/s) - ‘docker_install_en.sh’ saved [16976/16976]
--2024-05-08 17:50:25-- https://node.aapanel.com/install/0/docker_install_en.sh
selecting download node...
https://na1-node.bt.cn
{"product": "Linux panel", "setup_path": "/www/server", "openlitespeed_path": "/usr/local", "language": "English", "title": "Oracle Webhost", "brand": "aaPanel", "root_path": "/www", "template": "default", "logs_path": "/www/wwwlogs", "home": "https://www.aapanel.com", "recycle_bin": true}
Hit:1 http://eu-amsterdam-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports jammy InRelease
Hit:2 http://eu-amsterdam-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
Hit:3 http://eu-amsterdam-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
Ign:5 https://download.docker.com/linux/debian jammy InRelease
Get:6 https://esm.ubuntu.com/apps/ubuntu jammy-apps-security InRelease [7553 B]
Err:7 https://download.docker.com/linux/debian jammy Release
404 Not Found [IP: 52.222.169.49 443]
Get:8 https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates InRelease [7456 B]
Get:9 https://esm.ubuntu.com/infra/ubuntu jammy-infra-security InRelease [7450 B]
Get:10 https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates InRelease [7449 B]
Reading package lists...
E: The repository 'https://download.docker.com/linux/debian jammy Release' does not have a Release file.
Building dependency tree...
Reading state information...
ca-certificates is already the newest version (20230311ubuntu0.22.04.1).
curl is already the newest version (7.81.0-1ubuntu1.16).
apt-transport-https is already the newest version (2.4.12).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Hit:4 https://download.docker.com/linux/ubuntu jammy InRelease
Hit:5 https://esm.ubuntu.com/apps/ubuntu jammy-apps-security InRelease
Hit:6 https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates InRelease
Hit:7 https://esm.ubuntu.com/infra/ubuntu jammy-infra-security InRelease
Hit:8 https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates InRelease
Hit:9 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
The following additional packages will be installed:
containerd.io docker-ce-cli
Suggested packages:
cgroupfs-mount | cgroup-lite
Recommended packages:
docker-ce-rootless-extras pigz docker-buildx-plugin docker-compose-plugin
The following NEW packages will be installed:
containerd.io docker-ce docker-ce-cli
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
Need to get 50.1 MB of archives.
After this operation, 213 MB of additional disk space will be used.
Get:1 https://download.docker.com/linux/ubuntu jammy/stable arm64 containerd.io arm64 1.6.31-1 [21.5 MB]
Get:2 https://download.docker.com/linux/ubuntu jammy/stable arm64 docker-ce-cli arm64 5:26.1.1-1ubuntu.22.04jammy [13.2 MB]
Get:3 https://download.docker.com/linux/ubuntu jammy/stable arm64 docker-ce arm64 5:26.1.1-1ubuntu.22.04jammy [15.4 MB]
Fetched 50.1 MB in 1s (51.9 MB/s)
Selecting previously unselected package containerd.io.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 144707 files and directories currently installed.)
Preparing to unpack .../containerd.io_1.6.31-1_arm64.deb ...
Unpacking containerd.io (1.6.31-1) ...
Selecting previously unselected package docker-ce-cli.
Preparing to unpack .../docker-ce-cli_5%3a26.1.1-1ubuntu.22.04jammy_arm64.deb ...
Unpacking docker-ce-cli (5:26.1.1-1ubuntu.22.04jammy) ...
Selecting previously unselected package docker-ce.
Preparing to unpack .../docker-ce_5%3a26.1.1-1ubuntu.22.04jammy_arm64.deb ...
Unpacking docker-ce (5:26.1.1-1ubuntu.22.04jammy) ...
Setting up containerd.io (1.6.31-1) ...
Setting up docker-ce-cli (5:26.1.1-1ubuntu.22.04jammy) ...
Setting up docker-ce (5:26.1.1-1ubuntu.22.04jammy) ...
Processing triggers for man-db (2.10.2-1) ...
NEEDRESTART-VER: 3.5
NEEDRESTART-KCUR: 6.5.0-1021-oracle
NEEDRESTART-KEXP: 6.5.0-1021-oracle
NEEDRESTART-KSTA: 1
curl: (23) Failure writing output to destination
chmod: cannot access '/usr/libexec/docker/cli-plugins/docker-compose': No such file or directory
Requirement already satisfied: pytz in ./pyenv/lib/python3.7/site-packages (2019.3)
Requirement already satisfied: docker in ./pyenv/lib/python3.7/site-packages (4.2.0)
Requirement already satisfied: six>=1.4.0 in ./pyenv/lib/python3.7/site-packages (from docker) (1.16.0)
Requirement already satisfied: websocket-client>=0.32.0 in ./pyenv/lib/python3.7/site-packages (from docker) (1.2.3)
Requirement already satisfied: requests!=2.18.0,>=2.14.2 in ./pyenv/lib/python3.7/site-packages (from docker) (2.26.0)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in ./pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (1.26.7)
Requirement already satisfied: certifi>=2017.4.17 in ./pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2019.11.28)
Requirement already satisfied: charset-normalizer~=2.0.0 in ./pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2.0.12)
Requirement already satisfied: idna<4,>=2.5 in ./pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2.8)
/bin/systemctl
Warning: Stopping docker.service, but it can still be activated by:
docker.socket
Created symlink /etc/systemd/system/getty@tty1.service → /dev/null.
Synchronizing state of docker.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable docker
