Hello, I have a problem with aapanel. Here I explain...
I already have a domain + Website on Aapanel and it works fine
Then I want to create a new website, I have registered the domain, point the IP to my AAPanel IP. After that, I added the domain to aapanel with the "Add Website" feature. And it works, when accessed, the domain displays the default NGINX page as usual, this is Normal.
The problem started when I deleted all the files in the new website folder, because the basic script was the same as the first website that was already running, then I copied all the files from the main website to the new website folder (except the SSL verification file). Then I made changes and modified the script.
At the same time, I tried SET SSL on the new website, and it failed with the reason that the Verification File was not found.
I'm confused, I try to access my new website, it turns out that it displays content from the first website, even after modifying the script on the second website, it still displays content on the first website.
In fact, I tried deleting all the files on the new website, it still shows the content from the first website.
Even more, I tried deleting the new website from aapanel, and it was still showing the Content from the first website even when it was deleted.
Then I tried at the domain provider to delete my AApanel IP, then the website could not be accessed.
Then I tried again to return it to IP AApanel, and it returned to displaying the content of the first website earlier...
Then I tried to wait a few days, but it still happened, and after 2 weeks (today), I gave up and chose to use the domain on another server.
But today, I bought a new domain and did the same thing and sure enough, the same thing happened..
In essence, what is going on and what is the solution for me? Thank you AApanel...
