• Support
  • Problem applying ssl in aapanel
I issued it to apply ssl and applied it to the site, but the website opens with my connection IP that I tried to issue, but the website does not open with other IPs.
Which part should I check for this problem? I'm currently transferring a website from another server to a new server with aapanel, and all the websites that need to apply certificates are showing the same phenomenon.
The site where the certificate is applied is https://mindlepeople.com
Even now, it opens fine on my IP, but not on other IPs.
The Netip server uses Cloudflare.
Oh, the website with other ssl is currently connected to the existing server, and it opens fine.
    aaPanel_Kern I set ssl with file verification.
    I can try to verify with DNS, but if so, is it possible to renew automatically?
    aaPanel_Kern Thank you for your quick support.
    Port 443 was blocked in the firewall of the server company.
