angelTDW i have phpmyadmin 5.0 installed. how to update it? already have a working aapanel. don't want to disturb it
aaPanel_Kern angelTDW Hello, install phpmyadmin after uninstalling in the app store and choose version 5.2 during installation
phonkbad aaPanel_Kern I have the same error There is a maximum of 5.0 in the panel. I need to add it myself through the server 5.2
aaP_tangdinhvu aaPanel_Kern There is a little difficulty when pressing the phpmyadmin button, the url that is opened is not an ssl url, I have to change the ssl port on the browser manually, I have uninstalled and reinstalled several times, please fix it
aaPanel_Kern phonkbad Hello, install phpmyadmin after uninstalling in the app store and choose version 5.2 during installation
aaP_dens960 aaPanel_Kern I had the same problem. I uninstalled phpmyadmin and then reinstalled by selecting version 5.2 in the app store. Thanks everything is working!
aaPanel_Kern Hello, the database will not be deleted. Delete only for phpmyadmin program dimassubaktianto
aaPanel_Kern Hello, the panel uses http by default,This issue will be optimized in the future. aaP_tangdinhvu
