@aaPanel_Kern I have just reinstall google drive but error not fix
File "/www/server/panel/plugin/gdrive/gdrive_main.py", line 770, in <module>
q.execute_command(sys.argv)
`selecting download node...
Found existing installation: requests 2.27.0
Uninstalling requests-2.27.0:
Successfully uninstalled requests-2.27.0
Collecting requests==2.27
Using cached requests-2.27.0-py2.py3-none-any.whl.metadata (5.0 kB)
Collecting urllib3<1.27,>=1.21.1 (from requests==2.27)
Using cached urllib3-1.26.18-py2.py3-none-any.whl.metadata (48 kB)
Collecting certifi>=2017.4.17 (from requests==2.27)
Using cached certifi-2024.2.2-py3-none-any.whl.metadata (2.2 kB)
Collecting charset-normalizer~=2.0.0 (from requests==2.27)
Using cached charset_normalizer-2.0.12-py3-none-any.whl.metadata (11 kB)
Collecting idna<4,>=2.5 (from requests==2.27)
Using cached idna-3.6-py3-none-any.whl.metadata (9.9 kB)
Using cached requests-2.27.0-py2.py3-none-any.whl (63 kB)
Using cached certifi-2024.2.2-py3-none-any.whl (163 kB)
Using cached charset_normalizer-2.0.12-py3-none-any.whl (39 kB)
Using cached idna-3.6-py3-none-any.whl (61 kB)
Using cached urllib3-1.26.18-py2.py3-none-any.whl (143 kB)
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
google-api-core 1.24.1 requires google-auth<2.0dev,>=1.21.1, but you have google-auth 2.28.2 which is incompatible.
google-cloud-storage 2.15.0 requires google-api-core<3.0.0dev,>=2.15.0, but you have google-api-core 1.24.1 which is incompatible.
google-cloud-storage 2.15.0 requires google-cloud-core<3.0dev,>=2.3.0, but you have google-cloud-core 1.5.0 which is incompatible.
google-cloud-storage 2.15.0 requires google-resumable-media>=2.6.0, but you have google-resumable-media 1.2.0 which is incompatible.
Successfully installed certifi-2020.12.5 charset-normalizer-2.0.12 idna-2.10 requests-2.27.0 urllib3-1.26.18
--2024-03-26 08:32:15-- https://dg2.bt.cn/install/plugin/gdrive_en/gdrive.zip
Resolving dg2.bt.cn (dg2.bt.cn)... 103.179.243.14, 2001:19f0:7001:54fc:5400:2ff:fe9b:97f9
Connecting to dg2.bt.cn (dg2.bt.cn)|103.179.243.14|:443... connected.
Length: 16188 (16K) [application/zip]
Saving to: ‘/tmp/gdrive.zip’
0K .......... ..... 100% 94.0M=0s
2024-03-26 08:32:15 (94.0 MB/s) - ‘/tmp/gdrive.zip’ saved [16188/16188]
Archive: /tmp/gdrive.zip
creating: /www/server/panel/plugin/gdrive/
inflating: /www/server/panel/plugin/gdrive/credentials.json
inflating: /www/server/panel/plugin/gdrive/gdrive_main.py
inflating: /www/server/panel/plugin/gdrive/icon.png
inflating: /www/server/panel/plugin/gdrive/index.html
inflating: /www/server/panel/plugin/gdrive/info.json
inflating: /www/server/panel/plugin/gdrive/install.sh
inflating: /www/server/panel/plugin/gdrive/repair.sh
inflating: /www/server/panel/plugin/gdrive/upgrade.sh
