aaP_p2u_bazhou aaP_p2u_bazhou by the way i have done all these testing... and it is able to run with no connection issue.
aaPanel_Kern Hello, it is recommended to reinstall php. and check for errors. cat /tmp/panelExec.log aaP_p2u_bazhou
aaP_p2u_bazhou When i open my App Store page, it show the same error? Without App Store page UI, how can i reinstall php without affecting/losing my website data?
aaPanel_Kern Hello, is it normal now? Please try updating the list in the App store. Is it normal? aaP_p2u_bazhou
aaP_p2u_bazhou Still facing the issue and not yet solve. the App Store also have the error while clicked on it
aaP_p2u_bazhou aaPanel_Kern still having issue, my server located at Malaysia. What is the problem here?
aaPanel_Kern aaP_p2u_bazhou Hello, trying to check if the network can connect to our node? curl -v https://brandnew.aapanel.com ping brandnew.aapanel.com -c 5 ping google.com -c 5 curl -v http://brandnew.aapanel.com
aaPanel_Kern Have you restarted the panel? Is it normal to try to update the listing in the app store? If it still doesn't work, try repairing the panel aaP_p2u_bazhou
aaP_p2u_bazhou aaPanel_Kern After restart panel and repair panel + restart again, the issue still there. I need the help of panel to install redis and some other software, but i was stuck with this issue for long long time.
aaPanel_Kern aaP_p2u_bazhou Hello, which region is your server located in? Is the server network normal?
aaP_p2u_bazhou aaPanel_Kern Hi Kern, As from previous replied, my server located at Malaysia. network is definitely no issue. my website and other application is working fine. The aapanel other pages except dashboard and App are Ok too.
aaPanel_Kern Hello, is the problem solved? Is it normal to try restarting the panel? Also check if the server can connect to our node server? curl -v https://brandnew.aapanel.com ping brandnew.aapanel.com -c 5 ping google.com -c 5 curl -v http://brandnew.aapanel.com aaP_qiospaycare
aaP_mediadigitalxxi aaPanel_Kern hallo , i had the same problem, i used the code * Could not resolve host: brandnew.aapanel.com Closing connection 0 curl: (6) Could not resolve host: brandnew.aapanel.com Can you help me, because of this error my website is damaged
