bassam Hello Please help me for fix this 100%cpu 100%ram And after i stopped apach its show all 0% I dont know what i can do
aaPanel_Kern bassam Hello, it looks like it was attacked. Is the suggestion to use apache waf an effective solution?
aaPanel_Kern bassam Hello, check what is the cause. If it is a cc attack, you can use the system firewall to prohibit related ip access. You can also use Fail2ban Manager from the app store If it is a ddos attack, you need to use the ip that protects ddos
bassam aaPanel_Kern i try buy one month pro but you add payment method only visa and i try use my visa usa it's not working on your site
bassam aaPanel_Kern ok good thanks bro i will try and i hope you add soon payment method paypal and bitcoin thank you
