aaPanel_Kern Neto Hello, please check your network problem At the same time your server cpu usage is high
Neto aaPanel_Kern I already noticed and tried to limit the use of memory but so far I have not been able to lower the load on the CPU. Do you have any suggestion?
Neto The problem is that I lost the password and the user of one of the sites and I can only recover it through phpmyadmin. Do you know another way for me to discover this access data?
aaPanel_Kern Neto Hello, it is recommended to solve the problem of cpu occupation first, and it is difficult to use commands. You can try to use the mysql command to modify the password of the relevant user
aaPanel_Kern Neto It is recommended to increase the cpu, and see that the server has only 1 core, which is occupied by kswapd0
Neto Could you please enter the database called Mautic and look at the username and password and send me an email atetoconsultor360@gmail.com? I'm grateful
aaPanel_Kern Neto Hello, I don't know which table has a password, and the stored password is encrypted
Neto Hello friend, could you try to do this procedure that is in the link please? https://forum.mautic.org/t/reset-admin-password-via-ssh/10216 Because if I had access to phpmyadmin I would have done it. Access this link please and try to change my password, because I really need it. I thank.
