gacott I have tried multiple ways, multiple servers, and always get connection time out or connection failure. Tried with domains, IP, refreshed API key, whitelist of course, etc. Any help? Cent8, currently running Nginx Tengine on both servers.
aaPanel_Jose gacott execute this command in your ssh terminal curl http://your_panel_ip:8888 If there is a loginword in the returned content, It means connect seucess
gacott Getting ready to test this, but question first. I changed the port. It should be on the new port correct? Also, it should run on the new port just as well as the old port, right?
gacott Okay, nope http returns this curl: (56) Recv failure: Connection reset by peer and https this: curl failed to verify the legitimacy of the server and therefore could not establish a secure connection to it. To learn more about this situation and how to fix it, please visit the web page mentioned above.
gacott Okay, got it working. Does not seem to work if the pannel receiving the connection is in SSL mode. This has to be a bug right?
