aaP_gowtham26593 I can't able access my aaPanel. I tried "bt restart". But still, I am facing the same issue. Even I checked the error logs and found there are no errors in them. /www/server/panel/logs/error.log Please help me. Thanks in advance.
aaPanel_Kern aaP_gowtham26593 Hello, what does it mean when you can’t access? Try to change browsers or use incognito mode to access the complete link. Is it normal?
aaP_gowtham26593 Even I can't able to see my aaPanel login page. When I tried to open aaPanel, I am getting a "This site can’t be reached" message from the browser. But my sites are working without any issues. I tried to log in from all the different browsers.
aaPanel_Kern aaP_gowtham26593 Please check to access the panel bt 14 using the full link If still inaccessible, please take a screenshot of the inaccessible display.
deep9050 hey I'm facing the same issue. but not able to understand how can i run the bt 14 command could you please give me example .
aaPanel_Kern deep9050 Hello, use the ssh tool or terminal to execute the following command to check whether the panel is normal? bt 14 https://www.aapanel.com/forum/d/13132-aapanel-cannot-log-in-and-cannot-be-accessed-workaround
