aaP_leon6077 aaPanel_Kern Yea thats why idk i get the server error when i wanna do for example: apt-get update && apt-get upgrade
aaP_leon6077 aaP_leon6077 apt-get update && apt-get upgrade Like i said thoose errors come server wide when i try to update .....................................................
aaPanel_Kern Hello, I don't know what your problem is. The log above displays normally, so what problems do you have? aaP_leon6077
aaP_leon6077 aaPanel_Kern How is that log normal? aaP_leon6077 redis-server (6:7.0.5-1rl1focal1) wird eingerichtet ... Job for redis-server.service failed because the control process exited with error code. See "systemctl status redis-server.service" and "journalctl -xe" for details. invoke-rc.d: initscript redis-server, action "start" failed. ● redis-server.service - Advanced key-value store Loaded: loaded (/lib/systemd/system/redis-server.service; disabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Tue 2022-11-08 23:42:25 CET; 14ms ago Docs: http://redis.io/documentation, man:redis-server(1) Process: 346395 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=1/FAILURE) Main PID: 346395 (code=exited, status=1/FAILURE) Status: "Redis is loading..." Nov 08 23:42:25 kvm.XXXXX.com systemd[1]: redis-server.service: Failed with result 'exit-code'. Nov 08 23:42:25 kvm.XXXXX.com systemd[1]: Failed to start Advanced key-value store. dpkg: Fehler beim Bearbeiten des Paketes redis-server (--configure): »installiertes redis-server-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück dpkg: Abhängigkeitsprobleme verhindern Konfiguration von redis: redis hängt ab von redis-server (<< 6:7.0.5-1rl1focal1.1~); aber: Paket redis-server ist noch nicht konfiguriert. redis hängt ab von redis-server (>= 6:7.0.5-1rl1focal1); aber: Paket redis-server ist noch nicht konfiguriert. dpkg: Fehler beim Bearbeiten des Paketes redis (--configure): Abhängigkeitsprobleme - verbleibt unkonfiguriert Es wurde kein Apport-Bericht verfasst, da die Fehlermeldung darauf hindeutet, dass dies lediglich ein Folgefehler eines vorherigen Problems ist. Fehler traten auf beim Bearbeiten von: redis-server redis
aaPanel_Kern aaP_leon6077 Hello, what command did you use to execute? Panel mounted only systemctl status redis /etc/init.d/redis status At the same time, ExecStart=/usr/bin/redis-server /etc/redis/redis.conf is not a panel configuration
aaPanel_Kern aaP_leon6077 This is an update system and software dependency. The panel and the software used by the panel will not use this update.
aaPanel_Kern Check whether there is Redis installed in the system using the deb package dpkg -L redis
aaP_leon6077 aaPanel_Kern root@kvm:~# dpkg -L redis /. /usr /usr/share /usr/share/doc /usr/share/doc/redis /usr/share/doc/redis/NEWS.Debian.gz /usr/share/doc/redis/changelog.Debian.gz /usr/share/doc/redis/changelog.gz /usr/share/doc/redis/copyright /usr/share/doc/redis/00-RELEASENOTES.gz
aaPanel_Kern aaP_leon6077 Remove the Redis installed on the system and use the Redis installed on the panel apt remove redis Use the system's Redis to delete the Redis installed on the panel
aaP_kostanmick aaPanel_Kern Redis-Passwd Please go to the Redis manager --> Perform showing Error Even i enter the passwords still showing this. i am using Apache
aaPanel_Kern Hello, please check whether the redis configuration file is correct. try click "Fix" on the homepage to fix it. And delete the wrong 2 lines of configuration in the redis configuration file, and then configure the password aaP_kostanmick
