• Support
  • Panel error requests.exceptions.ConnectionError: ('Connection aborted.'
aaP_srt_stable_app
Hello, we may not be able to connect to our server to get the software list.
Log in to the server using SSH tool and execute the command to view the connection
ping brandnew.aapanel.com
  • Rebuilt URL to: https://brandnew.aapanel.com/
  • Trying 128.1.164.230...
  • TCP_NODELAY set
  • Connected to brandnew.aapanel.com (128.1.164.230) port 443 (#0)
  • ALPN, offering h2
  • ALPN, offering http/1.1
  • successfully set certificate verify locations:
  • CAfile: /etc/ssl/certs/ca-certificates.crt
    CApath: /etc/ssl/certs
  • TLSv1.3 (OUT), TLS handshake, Client hello (1):
  • TLSv1.3 (IN), TLS handshake, Server hello (2):
  • TLSv1.3 (IN), TLS Unknown, Certificate Status (22):
  • TLSv1.3 (IN), TLS handshake, Unknown (8):
  • TLSv1.3 (IN), TLS handshake, Certificate (11):
  • TLSv1.3 (IN), TLS handshake, CERT verify (15):
  • TLSv1.3 (IN), TLS handshake, Finished (20):
  • TLSv1.3 (OUT), TLS change cipher, Client hello (1):
  • TLSv1.3 (OUT), TLS Unknown, Certificate Status (22):
  • TLSv1.3 (OUT), TLS handshake, Finished (20):
  • SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
  • ALPN, server accepted to use h2
  • Server certificate:
  • subject: C=CN; ST=\U5E7F\U4E1C\U7701; O=\U5E7F\U4E1C\U5821\U5854\U5B89\U5168\U6280\U672F\U6709\U9650\U516C\U53F8; CN=*.aapanel.com
  • start date: Sep 7 00:00:00 2022 GMT
  • expire date: Oct 8 23:59:59 2023 GMT
  • subjectAltName: host "brandnew.aapanel.com" matched cert's "*.aapanel.com"
  • issuer: C=CN; O=sslTrus; CN=sslTrus (RSA) OV CA
  • SSL certificate verify ok.
  • Using HTTP2, server supports multi-use
  • Connection state changed (HTTP/2 confirmed)
  • Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
  • TLSv1.3 (OUT), TLS Unknown, Unknown (23):
  • Using Stream ID: 1 (easy handle 0x5558be6d67d0)
GET / HTTP/2
Host: brandnew.aapanel.com
User-Agent: curl/7.58.0
Accept: /
  • TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
  • TLSv1.3 (IN), TLS Unknown, Unknown (23):
  • Connection state changed (MAX_CONCURRENT_STREAMS updated)!
  • HTTP/2 stream 1 was not closed cleanly: PROTOCOL_ERROR (err 1)
  • Connection #0 to host brandnew.aapanel.com left intact
    curl: (92) HTTP/2 stream 1 was not closed cleanly: PROTOCOL_ERROR (err 1)
i am getting ping
PING brandnew.aapanel.com (128.1.164.230) 56(84) bytes of data.
64 bytes from 128.1.164.230 (128.1.164.230): icmp_seq=1 ttl=58 time=176 ms
64 bytes from 128.1.164.230 (128.1.164.230): icmp_seq=2 ttl=58 time=175 ms
64 bytes from 128.1.164.230 (128.1.164.230): icmp_seq=3 ttl=58 time=175 ms
64 bytes from 128.1.164.230 (128.1.164.230): icmp_seq=4 ttl=58 time=175 ms
64 bytes from 128.1.164.230 (128.1.164.230): icmp_seq=5 ttl=58 time=175 ms
C
--- brandnew.aapanel.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4515ms
rtt min/avg/max/mdev = 175.499/175.749/176.316/0.604 ms
    i am new to Aapanel so i wanted to know if i use bt 16 repair cmd will it stop node servers that are currently running along with other plugins or php mysql ?
