aaPanel_Kern aaP_idfernn hello, phpmyadmin needs file file mode to use. kipak.my.id site error phpfastcache requires you to check it yourself
aaPanel_Kern aaP_idfernn The problem of the Kipak.my.id website needs to be dealt with by yourself. the php version used by phpmyadmin cannot be set on redis. it is recommended that you install php for phpmyadmin
aaP_idfernn aaPanel_Kern So I must use multiple php on my panel? and I must set different php for redis and phpmyadmin?
aaP_idfernn aaPanel_Kern Can you check on my site? kipak.my.id, why that site have a like redirection?
aaPanel_Kern aaP_idfernn yes. phpmyadmin has no redis support configuration. please check whether the error log and configuration file are correct i tried to restart nginx prompts 68 lines at the kipak.my.id site error
aaP_idfernn aaPanel_Kern Can I get back website like before this problem? Im already backup via cron site & db
aaPanel_Kern aaP_idfernn The cron restores the files and databases of the website. There is no nginx site configuration file The site configuration file of nginx is in the compressed package under/www/backup/panel/. Extract the file without modifying the previous date, enter the site configuration file in vhost/nginx, open it, directly select all the files to copy, and then paste them into the site configuration of the website
aaP_idfernn aaPanel_Kern So I must copy too all configuration on vhost/nginx and delete it, and then create again file that?
aaPanel_Kern aaP_idfernn you try to restart nginx, there is still a problem with the configuration. Solve it according to the prompts
aaPanel_Kern aaP_idfernn You should know what the parameter you configured is. Try to annotate related lines with #, and then restart nginx
aaP_idfernn aaPanel_Kern I have done restore, but I just can get back the web not database, Im lose my database 😢 Im to try import db, but always getting error 500 and I dont know where the problem.
aaPanel_Kern aaP_idfernn How do you delete the database? Try to manually download to Google Drive, and then upload to the server to restore /www/backup/database is the directory where database backups are stored
aaP_idfernn aaPanel_Kern I know why I cant use my old database, because it is use redis for cache files, and now I cant use redis because php 😢 How to get back redis to my php, because before it I can use redis for my php, and I just use 1 php before it
aaP_idfernn aaPanel_Kern Solved sir, I can use redis again for my php, and all my site still can use redis for cache
aaPanel_Kern aaP_idfernn In PHP, you can set Redis, or need to modify your website configuration file?
