aaPanel_Kern aaP_idfernn This may require you to add relevant content on the website of the website developer. This is the URL rewrite of the aapanel
aaP_idfernn aaPanel_Kern Im already to change mvc but my website still cannot access and get 403 forbidden I have the config for Nginx to web php, but I cant copas the config because Im just use mobile phone.
aaPanel_Kern aaP_idfernn Hello, what is the permission of the website directory? Check the error log of the website at the same time
aaP_idfernn aaPanel_Kern That problem is solved, but I have a problem again, why I cant install 'gmp' extension? I have already installed and then in log success but after Im restart the panel, the extension not installed.
aaPanel_Kern configure: error: GNU MP Library version 4.2 or greater required. ubuntu/debian: apt-get install libgmp-dev centos: yum -y install gmp-devel
aaP_idfernn aaPanel_Kern Sir, why I cant find dir usr/bin/php ? Im already enter the command whereis php or which php but said on usr/bin/php I just can see usr/bin not folder /php like this screenshot
aaPanel_Kern aaP_idfernn Hello, for example, the php directory where the php7.4 panel is installed is/www/server/php/74/bin/php
