Raffi
Hello, it is not possible to clear it directly.
You can create a Cut Log in the Cron interface, and the execution time depends on your needs. After adding, click Execute to backup and compress the log.
The logs for all sites at this time are empty. Then visit the website. Finally, go to the Log Security Analysis in the Response log of the Conf interface of the website and click the log scan, which is cleared.
