aaP_Pradiprajbhar562 when i upload any new plugin in wordpress, i am geting error - Error Establishing a Database Connection and msql server automatic shutdown. how can i fix this Error.
aaPanel_Kern aaP_Pradiprajbhar562 Hello, do you have more information? Check whether the database runs normally? Whether the database information filled in is normal View database error log cat /www/server/data/*.err|grep -i -C 10 error
aaP_visualcreaciones buenas tardes tengo un problema con mi panel pues necesitaba cambiar la version de mysql desinstale he hice nuevamente la instalaciĆ³n, pero no quiere iniciar, ejecute el comando cat /www/server/data/*.err|grep -i -C 10 error
aaPanel_Kern Hello, check the mysql configuration file, and the log indicates that the PID file does not exist aaP_visualcreaciones
