Apache My Aapanel login no longer works either. When I call :7800/login, 404 appears. Does anyone have a solution? .... Edit: I have access again. The panel ran for 154 days, now it shows zero as if it ran for the first time today. What is this?
aaPanel_Kern The running time in the panel refers to the running time of the server When 404 appears in the panel access, it means that the complete access link is not used
aaP_saifullahshams2 aaPanel_Kern For me "bt 12" worked but before I deleted the domain using this commend "nano /www/server/panel/data/domain.conf"
aaP_alexisacm72 Hi, I created new website (first time using aaPanel) the domain runs well and default index.html with congratulations message was working, when uploaded php system, I get always 404 error. php.ini setting was added, extensions added, database created and updated. Some help, thanks
aaPanel_Kern Hello, try deleting the index.html file, using the browser in incognito mode or changing the browser to access it. Is it the same? Do you need to set URL rewirte? aaP_alexisacm72
aaP_tuanbinhhai aaPanel_Kern Hi @aaPanel_Kern, I also have same error with you, but I cant know how can I login with the same screen above of you, when I ssh root after Reboot in rescue mode I cant see any files of aapanel and can't run command bt. Coul you please guide me this step?
aaPanel_Kern Hello, are there any prompts about the inability to run the command? Have you executed the command with root privileges? aaP_tuanbinhhai
aaPanel_Kern Hello, do you want to install aapanel? Check out this directory ls -l /www/server aaP_tuanbinhhai
aaP_tuanbinhhai aaPanel_Kern I run command and get error ls: cannot access '/www/server': No such file or directory
aaP_tuanbinhhai aaPanel_Kern I have installed before, but when I login with account root when reboot rescue mode, I can’t see aapanel. Have another way to delete bind domain?
