aaP_shresthalokesh aaPanel_Kern i wanted to set domain for panel but when i put domain i am not able to access panel.. can you guid on full process.. thanks
aaP_shresthalokesh thanks for your guide but i see am unable to open once i bind panel with domain https://prnt.sc/xxx
aaPanel_Kern Is it normal to use the correct link to visit? The bt 14 command can view the link aaP_shresthalokesh
aaPanel_Kern Hello, could you please describe the problem in detail or provide a screenshot? aaP_skytechnggroup
