ghulamid
Hi
#centos
yum install -y htop && htop
#debian/ubuntu
apt update
apt install -y htop && htop
or top command analysis
If you can’t analyze website logs, the software store has [Website statistics], which can be used to visually check the logs to see which website requests and accesses are currently abnormal. If a large number of requests come in within 1 second or a few seconds, there is a high probability of being hit. Yes, you can install our [nginx waf] plugin to block attacks
