aaP_advup Hello, I updated ubuntu 20.04 to version 22.04, now applications from the app store are not installed in the aapanel panel - Loading... hangs. Tell me how to update ubuntu to a new version with aapanel installed?
aaPanel_Kern aaP_advup Hello, aapanel is a management software. Upgrading the system may affect the operation of aapanel. Upgrading the system will not upgrade the aapanel. They are independent programs aapanel needs to click "update" on the home page to upgrade The stable version is 6.28.6 The test version is 6.9.67
aaPanel_Kern aaP_mdestafadilah_simrs This is up to you to choose. Upgrading the system may affect the operation of aapanel. There are also some applications that are not adapted
aaP_advup aaPanel_Kern Hello, is there any way to fix this? After updating ubuntu 20.04 to 22.04, no new applications from the app store are installed, the installation hangs or an error is thrown.
aaP_advup aaP_advup This is not only with openlitespeed, but with all other applications, even nginx, apache.
Vean i recomended use Ubuntu 20.04 until problem solve 😃.. i test 22.04, many problem installing Apps.
