When I click on the website SSL settings, it will show:
ModuleNotFoundError: No module named 'dns.resolver'
File "/www/server/panel/class/acme_v2.py", line 37, in
import dns.resolver
File "/home/www/server/panel/BTPanel/init.py", line 1688, in publicObject
File "/home/www/server/panel/BTPanel/init.py", line 1636, in run
File "class/panelSite.py", line 2184, in GetSSL
import acme_v2
File "/www/server/panel/class/acme_v2.py", line 40, in
import dns.resolver
My OS is debian,
after I run "btpip install dnsPython",
it shows Requirement already satisfied: dnsPython in /home/www/server/panel/pyenv/lib/python3.7/site-packages (1.16.0)
I can successfully install a python3-dnspython with "apt install python3-dnspython", but it still doesn't work in aapanel, it still reports the no module named 'dns.resolver'
What do I need to do to use ssl normally? thank you!
    aaP_puyang
    Requirement already compatible: dnsPython in /home/www/server/panel/pyenv/lib/python3.7/site-packages (1.16.0)
    this is normal. Have you restarted the panel after executing the command? Is it normal now?
    bt 1
    After uninstalling and reinstalling, it works fine, thank you!
    Every time I restart, this problem recurs several times. Whether I uninstall python3-dnspython or not, btpip will prompt me that dnsPython already exists. But in the aapanel, it still reports that the module named 'dns.resolver is not found. My system is Debian 11
      aaP_puyang
      The panel uses the module installed by btpip, will it reproduce after restarting?
      bt 1
