Manual ssl Certificate Renewal
aaP_randreevich
If you can't renew, try to close SSL and apply for SSL. At the same time, what version is your panel?
On the server it was updated, but on clients does not see.
The panel version is current 6.8.26
aaP_randreevich
Does the client mean the browser? If yes, please clear the cache or use private mode to access
- Edited
Client - Outlook, mobile phones...
aaP_randreevich
Try to apply for SSL again
Turn on?
aaP_randreevich
What does the mobile browser prompt?
The phone does not have a browser, but an email client. He does not see the certificate.
Outlook on the computer also does not see the certificate.
Browser - ok
aaP_randreevich
Then check the SSL of the mail server. The SSL of the website is not the same as the SSL of the mail server.
Please tell me where to do it?
aaP_randreevich
Check the app store to see if it is installed. If not installed. It is recommended that you consult the relevant person in charge
What needs to be installed?
aaP_randreevich
What do you mean by client? What is a cell phone? Under what circumstances can I not view the certificate?
Outlook is the client of the mail server. Are you using the mail server on our panel? Check in the app store to see if it's installed
Yes, we use a mail server in your panel.
Installed in the store.
aaP_randreevich
Check if the mail server's SSL is ok?
mail server ssl is ok.
aaPanel_Kern Try to apply for SSL again
- Edited
openssl s_client -connect xxx.com:587 -starttls smtp
If not ok. Please reapply
