aaP_rankboosterfr Hi, my SMTP is not working. I am able to send et receive email inside aapanel BUT, once i tried using the SMTP like in my laravel app mailfox, Firebird or etc noting occurs can you. Keep getting error. Aapanel can you please help?
aaPanel_Kern aaP_rankboosterfr hi, What is the error message? Please check the log of the mail server and the content of the prompt to troubleshoot the problem
aaP_rankboosterfr aaPanel_Kern Thank so much for replying here is the screenshot error https://prnt.sc/QA3a7LEOraIJ
aaPanel_Kern aaP_rankboosterfr Login failed: SASL LOGIN authentication failed: Connection lost to authentication Check if the email address and password are correct?
aaP_rankboosterfr aaP_rankboosterfr It is working only with thunderbird. When I use the same credential in the app i get the following error
aaPanel_Kern aaP_rankboosterfr Does trying to re-apply for SSL fix it? Or the application uses port 25 without SSL
aaP_rankboosterfr aaPanel_Kern log: Aug 26 11:51:27 gofoodr postfix/smtpd[46113]: connect from unknown[5.34.207.88] Aug 26 11:51:27 gofoodr postfix/smtpd[46567]: disconnect from unknown[5.34.207.88] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4 Aug 26 11:51:30 gofoodr postfix/smtpd[46162]: warning: unknown[5.34.207.88]: SASL LOGIN authentication failed: Connection lost to authentication server Aug 26 11:51:30 gofoodr postfix/smtpd[47335]: connect from unknown[5.34.207.88] Aug 26 11:51:30 gofoodr postfix/smtpd[46162]: disconnect from unknown[5.34.207.88] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4 Aug 26 11:51:33 gofoodr postfix/smtpd[47279]: warning: unknown[5.34.207.88]: SASL LOGIN authentication failed: Connection lost to authentication server
aaP_rankboosterfr aaP_rankboosterfr I'm afraid the SMTP IS NOT working on an app. I did re-apply for SSL. the application uses 587 and 465 port. I'm stuck :
