aaP_thomas_marcelino When trying to install mysql (mysql-mariadb_10.7) it just keeps loading and never starts. I already restarted server, aapanel service and everything, what to do? Instalado no Ubuntu 20.04.4 LTS
aaPanel_Kern aaP_thomas_marcelino Just wait for its installation to complete. Check if the installation is successful, if it fails, check the log for what caused the problem.
ugurc I also had the same problem.Delete as . Restart the panel.I installed version mariadb 10.5, no problem.
aaP_thomas_marcelino and I'm going to install the company's server vimthough, now right, I believe that version 10.7 is higher to download elar. All very well. Solved! Execution log just looked like this
maxx To resolve this, you'll need to ensure that GnuTLS is installed on your system and that CMake can locate it during the MariaDB build process. sudo apt-get install gnutls-bin sudo apt-get install libgnutls28-dev gnutls-cli --version
