codeplx Hey, If you order pro, do you have to pay per installation? Or do you buy pro and can use it on as many server installations as you have? Thanks
aaPanel_Kern codeplx Hello, the pro minimum validity period is 1 month. A pro can only be used on one server. If you change the server, you can go to the official website to unbind, and then bind to the new server
annhienltd hi @aaPanel_Kern i have a question. If I buy aapanel lifetime version, can I use Pro-Plugins lifetime ?
zohebnsr aaPanel_Kern It is mentioned that you get paid plugin for a year even for lifetime. You should edit it and make it lifetime then.
aaPanel_Kern Hello, thank you for your feedback. It has been reported to the relevant person in charge. zohebnsr
