Hello, dear developers. I had an unexpected situation. I googled for two hours and didn't find a solution π Deleting and reinstalling the plugin is not an option π
[root@centos-4gb-nbg1-1 ~]# systemctl status mysqld.service
β mysqld.service - LSB: start and stop MariaDB
Loaded: loaded (/etc/rc.d/init.d/mysqld; bad; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2022-08-11 21:34:06 UTC; 5s ago
Docs: man:systemd-sysv-generator(8)
Process: 2408 ExecStart=/etc/rc.d/init.d/mysqld start (code=exited, status=1/FAILURE)
Aug 11 21:34:04 centos-4gb-nbg1-1 systemd[1]: Starting LSB: start and stop M....
Aug 11 21:34:05 centos-4gb-nbg1-1 mysqld[2408]: Starting MariaDB.220811 21:3....
Aug 11 21:34:05 centos-4gb-nbg1-1 mysqld[2408]: 220811 21:34:05 mysqld_safe ...a
Aug 11 21:34:06 centos-4gb-nbg1-1 mysqld[2408]: /etc/rc.d/init.d/mysqld: lin...s
Aug 11 21:34:06 centos-4gb-nbg1-1 mysqld[2408]: ERROR!
Aug 11 21:34:06 centos-4gb-nbg1-1 systemd[1]: mysqld.service: control proces...1
Aug 11 21:34:06 centos-4gb-nbg1-1 systemd[1]: Failed to start LSB: start and....
Aug 11 21:34:06 centos-4gb-nbg1-1 systemd[1]: Unit mysqld.service entered fa....
Aug 11 21:34:06 centos-4gb-nbg1-1 systemd[1]: mysqld.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
2022-08-11 21:27:26 0 [Note] InnoDB: Compressed tables use zlib 1.2.7
2022-08-11 21:27:26 0 [Note] InnoDB: Number of transaction pools: 1
2022-08-11 21:27:26 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2022-08-11 21:27:26 0 [Note] InnoDB: Using Linux native AIO
2022-08-11 21:27:26 0 [Note] InnoDB: Initializing buffer pool, total size = 268435456, chunk size = 134217728
2022-08-11 21:27:26 0 [Note] InnoDB: Completed initialization of buffer pool
2022-08-11 21:27:26 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=42373,42373
2022-08-11 21:27:26 0 [ERROR] InnoDB: Missing FILE_CHECKPOINT at 42373 between the checkpoint 42373 and the end 11641987.
2022-08-11 21:27:26 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2022-08-11 21:27:26 0 [Note] InnoDB: Starting shutdown...
2022-08-11 21:27:26 0 [ERROR] Plugin 'InnoDB' init function returned error.
2022-08-11 21:27:26 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2022-08-11 21:27:26 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-08-11 21:27:26 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2022-08-11 21:27:26 0 [ERROR] Aborting
220811 21:27:26 mysqld_safe mysqld from pid file /www/server/data/centos-4gb-nbg1-1.pid ended
220811 21:31:05 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2022-08-11 21:31:05 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2022-08-11 21:31:05 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 3317 ...
2022-08-11 21:31:05 0 [Note] InnoDB: Compressed tables use zlib 1.2.7
2022-08-11 21:31:05 0 [Note] InnoDB: Number of transaction pools: 1
2022-08-11 21:31:05 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2022-08-11 21:31:05 0 [Note] InnoDB: Using Linux native AIO
2022-08-11 21:31:05 0 [Note] InnoDB: Initializing buffer pool, total size = 268435456, chunk size = 134217728
2022-08-11 21:31:05 0 [Note] InnoDB: Completed initialization of buffer pool
2022-08-11 21:31:05 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=42373,42373
2022-08-11 21:31:05 0 [ERROR] InnoDB: Missing FILE_CHECKPOINT at 42373 between the checkpoint 42373 and the end 11641987.
2022-08-11 21:31:05 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2022-08-11 21:31:05 0 [Note] InnoDB: Starting shutdown...
2022-08-11 21:31:05 0 [ERROR] Plugin 'InnoDB' init function returned error.
2022-08-11 21:31:05 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2022-08-11 21:31:05 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-08-11 21:31:05 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2022-08-11 21:31:05 0 [ERROR] Aborting
220811 21:31:05 mysqld_safe mysqld from pid file /www/server/data/centos-4gb-nbg1-1.pid ended
220811 21:31:58 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2022-08-11 21:31:58 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2022-08-11 21:31:58 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 1995 ...
2022-08-11 21:31:58 0 [Note] InnoDB: Compressed tables use zlib 1.2.7
2022-08-11 21:31:58 0 [Note] InnoDB: Number of transaction pools: 1
2022-08-11 21:31:58 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2022-08-11 21:31:58 0 [Note] InnoDB: Using Linux native AIO
2022-08-11 21:31:58 0 [Note] InnoDB: Initializing buffer pool, total size = 268435456, chunk size = 134217728
2022-08-11 21:31:58 0 [Note] InnoDB: Completed initialization of buffer pool
2022-08-11 21:31:58 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=42373,42373
2022-08-11 21:31:58 0 [ERROR] InnoDB: Missing FILE_CHECKPOINT at 42373 between the checkpoint 42373 and the end 11641987.
2022-08-11 21:31:58 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2022-08-11 21:31:58 0 [Note] InnoDB: Starting shutdown...
2022-08-11 21:31:58 0 [ERROR] Plugin 'InnoDB' init function returned error.
2022-08-11 21:31:58 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2022-08-11 21:31:58 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-08-11 21:31:58 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2022-08-11 21:31:58 0 [ERROR] Aborting
220811 21:31:58 mysqld_safe mysqld from pid file /www/server/data/centos-4gb-nbg1-1.pid ended
220811 21:34:05 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2022-08-11 21:34:05 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2022-08-11 21:34:05 0 [Note] /www/server/mysql/bin/mariadbd (server 10.7.3-MariaDB-log) starting as process 2729 ...
2022-08-11 21:34:05 0 [Note] InnoDB: Compressed tables use zlib 1.2.7
2022-08-11 21:34:05 0 [Note] InnoDB: Number of transaction pools: 1
2022-08-11 21:34:05 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2022-08-11 21:34:05 0 [Note] InnoDB: Using Linux native AIO
2022-08-11 21:34:05 0 [Note] InnoDB: Initializing buffer pool, total size = 268435456, chunk size = 134217728
2022-08-11 21:34:05 0 [Note] InnoDB: Completed initialization of buffer pool
2022-08-11 21:34:05 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=42373,42373
2022-08-11 21:34:05 0 [ERROR] InnoDB: Missing FILE_CHECKPOINT at 42373 between the checkpoint 42373 and the end 11641987.
2022-08-11 21:34:05 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2022-08-11 21:34:05 0 [Note] InnoDB: Starting shutdown...
2022-08-11 21:34:05 0 [ERROR] Plugin 'InnoDB' init function returned error.
2022-08-11 21:34:05 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2022-08-11 21:34:05 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-08-11 21:34:05 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2022-08-11 21:34:05 0 [ERROR] Aborting
220811 21:34:05 mysqld_safe mysqld from pid file /www/server/data/centos-4gb-nbg1-1.pid ended
