aaP_samzsakerz Hello, I have a node.js project that I am running using the website panel, I can access it fine using my domain after setting up the DNS, but I would also like to access it using the IP address, when I do visit IP:PORT I get greated with a 110 connection failed.
aaPanel_Kern aaP_samzsakerz Hello, please add the ip address to the domain name of the site and try if it can be accessed? Do you have a port when you access the domain name, and you don't need to use the port if there is no added ip? If there is a mail server installed, port 110 will already be occupied
gaurav_nsl I have added that I am still not able to access the node project, actually, I wanted to run the project with IP on port 3001 still I am not able to do that through IP, Can you please help me with it TIA
aaPanel_Kern Hello, is the project running? Is it normal to access using the domain name? Is the relevant port listening? gaurav_nsl
