chrispy Hey @all, could you please add 'php-ldap' to 'Install extensions'? unfortunately I can not install this extension myself 😅 greeting christian
aaPanel_Jose chrispy It has been added to the php extension. If you cannot see it, you can execute bt 9in the terminal to clear the panel cache
chrispy aaPanel_Jose "LDAP configuration updated successfully" Thank you so much! You are doing a really good job with aaPanel!
