thiagotgc I did a Fail2Ban test for the wrong password with SSH. It detects correctly, and adds the IP to the panel, but it does not block the IP. I am still able to access SSH. See the image: CentOS 7.8 aaPanel 6.6.9
aaPanel_Jose thiagotgc The established ip connection will not be released, you can try to close the connection in use, and then try to log in and authentication will be blocked
thiagotgc aaPanel_Jose I opened Putty and typed in wrong passwords, he found the IP, and marked it as blocked. But I can still keep trying with the wrong passwords, and Fail2Ban will keep adding to the panel, but it won't block.
aaPanel_Jose thiagotgc I found this problem because of the problem caused by installing the failban dev version. I have given feedback to the developers of fail2ban and changed the installation version to a stable version. Please reinstall fail2ban
aaP_karanjotcoool [unknown] i am having the same issue it shows the ip in the log but it never blocks that ip! please help me so it blocks the ip what do i have to do?
