kamranhanif496
Bro, you can´t use 2 SSL certificates in 1 row. Use only Cloudflares SSL or Lets Encrypt. When you want use the FULL on Cloudflare then must download from Cloudflare that SSL and import in aaPanel. Only 1 encryption at time...
When Cloudflare routing to your server with CF SSL, and getting back Lets Encrypt SSL, he say: "WTF is this???" This isn´t like mine encryption, who want manipulate? Error 526, not acceptable.
(When you import SSL to aaPanel, and set the CF there will be minimum 24 hours to set, when no more...)
