i have same problem cant update
timeout=timeout
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 531, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/packages/six.py", line 735, in reraise
raise value
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 447, in make_request
self.raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 337, in _raise_timeout
self, url, "Read timed out. (read timeout=%s)" % timeout_value
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Read timed out. (read timeout=6)
File "/www/server/panel/class/http_requests.py", line 103, in post
result = requests.post(url,data,timeout=timeout,headers=headers,verify=verify)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 119, in post
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Read timed out. (read timeout=6)
[2024-09-19 12:53:32][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 445, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 440, in make_request
httplib_response = conn.getresponse()
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1369, in getresponse
response.begin()
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 310, in begin
version, status, reason = self.read_status()
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 271, in read_status
line = str(self.fp.readline(MAXLINE + 1), "iso-8859-1")
File "/www/server/panel/pyenv/lib/python3.7/socket.py", line 589, in readinto
return self.sock.recv_into(b)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 567, in recv_into
return self.read(nbytes, buffer)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 390, in read
self.wait(self.read_event, timeout_exc=SSLErrorReadTimeout)
File "src/gevent/hub_primitives.py", line 317, in gevent.gevent_c_hub_primitives.wait_on_socket
File "src/gevent/hub_primitives.py", line 322, in gevent.gevent_c_hub_primitives.wait_on_socket
File "src/gevent/hub_primitives.py", line 313, in gevent.gevent_c_hub_primitives.primitive_wait
File "src/gevent/hub_primitives.py", line 314, in gevent.gevent_c_hub_primitives.primitive_wait
File "src/gevent/hub_primitives.py", line 46, in gevent.gevent_c_hub_primitives.WaitOperationsGreenlet.wait
File "src/gevent/hub_primitives.py", line 55, in gevent.gevent_c_hub_primitives.WaitOperationsGreenlet.wait
File "src/gevent/waiter.py", line 154, in gevent.gevent_c_waiter.Waiter.get
File "src/gevent/greenlet_primitives.py", line 61, in gevent.gevent_c_greenlet_primitives.SwitchOutGreenletWithLoop.switch
File "src/gevent/greenlet_primitives.py", line 65, in gevent.gevent_c_greenlet_primitives.SwitchOutGreenletWithLoop.switch
File "src/gevent/gevent_c_greenlet_primitives.pxd", line 35, in gevent.gevent_c_greenlet_primitives._greenlet_switch
socket.timeout: The read operation timed out
timeout=timeout
raise value
chunked=chunked,
