aaPanel_Kern friczky The panel does not support the specified user to execute composer and npm, and can only be run by the root or www user. You can use the terminal to execute using the command. Also this has nothing to do with the domain name.
JAY aaPanel_Kern same information i raised before we will not able to run compuser with user www while runing it show user not found did you tested it
aaPanel_Kern JAY Hello, I did not test to say that the user could not be found, but This account is currently not available You can use this command to specify www execution: sudo -u www command
rico I agree, sometimes we need a specific user can create, run composer, and other non root command is there any suggestion on how to do without a sudo
