aaPanel_Kern aaP_cristiano_joilson Hello, try to click "Fix" on the home page of the panel to repair the panel, whether it can solve this problem?
aaP_cristiano_joilson aaPanel_Kern I did that already and it didn't solve the problem and then it won't let me enter the panel again. I have to system restore all on digitalocean
aaP_cristiano_joilson aaPanel_Kern sorry for the delay, it didn't fix a problem, every time i have to make a backup
aaPanel_Kern aaP_cristiano_joilson Hi, can you give us your aapanel information? The server makes a snapshot backup first, if possible, please send it to kern@aapanel.com. It is recommended to fill in the following Post link: SSH IP address, account password and port: aapanel login link address and account password:
aaPanel_Kern aaP_surya_kurniawan35 Hello, try to use the SSH tool to log in to the server and execute commands with root privileges, and then try again, can it be resolved? bt 16
aaPanel_Kern omnichannel Hello, where is your server located? trying to check if the network can connect to our node? curl -v https://brandnew.aapanel.com ping brandnew.aapanel.com -c 5 ping google.com -c 5 curl -v http://brandnew.aapanel.com
omnichannel aaPanel_Kern Services do not start automatically after I restart the VPS. Do we have any way to fix this problem? For example: redis...
