phpinfo()
PHP Version => 7.4.28
System => Linux vps-f301ea70.vps.ovh.us 3.10.0-1160.71.1.el7.x86_64 #1 SMP Tue Jun 28 15:37:28 UTC 2022 x86_64
Build Date => Apr 4 2022 11:51:39
Build System => Linux af9babe063634951b98aa3147b9a83f5 4.18.0-348.12.2.el8_5.x86_64 #1 SMP Wed Jan 19 17:53:40 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => /usr/local/lsws/lsphp74/etc
Loaded Configuration File => /usr/local/lsws/lsphp74/etc/php.ini
Scan this dir for additional .ini files => /usr/local/lsws/lsphp74/etc/php.d
Additional .ini files parsed => /usr/local/lsws/lsphp74/etc/php.d/10-opcache.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-bz2.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-calendar.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-ctype.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-curl.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-dom.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-exif.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-fileinfo.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-ftp.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-gd.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-gettext.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-iconv.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-imap.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-intl.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-json.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-mbstring.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-mysqlnd.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-pdo.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-phar.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-posix.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-shmop.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-simplexml.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-sockets.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-sqlite3.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-sysvmsg.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-sysvsem.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-sysvshm.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-tokenizer.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-xml.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-xmlwriter.ini,
/usr/local/lsws/lsphp74/etc/php.d/20-xsl.ini,
/usr/local/lsws/lsphp74/etc/php.d/30-mcrypt.ini,
/usr/local/lsws/lsphp74/etc/php.d/30-mysqli.ini,
/usr/local/lsws/lsphp74/etc/php.d/30-pdo_mysql.ini,
/usr/local/lsws/lsphp74/etc/php.d/30-pdo_sqlite.ini,
/usr/local/lsws/lsphp74/etc/php.d/30-xmlreader.ini,
/usr/local/lsws/lsphp74/etc/php.d/40-igbinary.ini,
/usr/local/lsws/lsphp74/etc/php.d/50-redis.ini
PHP API => 20190902
PHP Extension => 20190902
Zend Extension => 320190902
Zend Extension Build => API320190902,NTS
PHP Extension Build => API20190902,NTS
Debug Build => no
Thread Safety => disabled
Zend Signal Handling => enabled
Zend Memory Manager => enabled
Zend Multibyte Support => provided by mbstring
IPv6 Support => enabled
DTrace Support => available, disabled
Registered PHP Streams => https, ftps, compress.zlib, php, file, glob, data, http, ftp, zip, compress.bzip2, phar
Registered Stream Socket Transports => tcp, udp, unix, udg, ssl, sslv3, tls, tlsv1.0, tlsv1.1, tlsv1.2
Registered Stream Filters => zlib., string.rot13, string.toupper, string.tolower, string.strip_tags, convert., consumed, dechunk, bzip2., convert.iconv., mcrypt., mdecrypt.
This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.4.0, Copyright (c) Zend Technologies
with Zend OPcache v7.4.28, Copyright (c), by Zend Technologies
Configuration
bz2
BZip2 Support => Enabled
Stream Wrapper support => compress.bzip2://
Stream Filter support => bzip2.decompress, bzip2.compress
BZip2 Version => 1.0.6, 6-Sept-2010
calendar
Calendar support => enabled
Core
Directive => Local Value => Master Value
allow_url_fopen => On => On
allow_url_include => Off => Off
arg_separator.input => & => &
arg_separator.output => & => &
auto_append_file => no value => no value
auto_globals_jit => On => On
auto_prepend_file => no value => no value
browscap => no value => no value
default_charset => UTF-8 => UTF-8
default_mimetype => text/html => text/html
disable_classes => no value => no value
disable_functions => passthru,exec,system,chroot,chgrp,chown,shell_exec,popen,proc_open,pcntl_exec,ini_alter,ini_restore,dl,openlog,syslog,readlink,symlink,popepassthru,pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,apache_setenv => passthru,exec,system,chroot,chgrp,chown,shell_exec,popen,proc_open,pcntl_exec,ini_alter,ini_restore,dl,openlog,syslog,readlink,symlink,popepassthru,pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,apache_setenv
display_errors => Off => Off
display_startup_errors => Off => Off
doc_root => no value => no value
docref_ext => no value => no value
docref_root => no value => no value
enable_dl => Off => Off
enable_post_data_reading => On => On
error_append_string => no value => no value
error_log => no value => no value
error_prepend_string => no value => no value
error_reporting => 22527 => 22527
expose_php => On => On
extension_dir => /usr/local/lsws/lsphp74/lib64/php/modules => /usr/local/lsws/lsphp74/lib64/php/modules
file_uploads => On => On
hard_timeout => 2 => 2
highlight.comment => #FF8000 => #FF8000
highlight.default => #0000BB => #0000BB
highlight.html => #000000 => #000000
highlight.keyword => #007700 => #007700
highlight.string => #DD0000 => #DD0000
html_errors => Off => Off
ignore_repeated_errors => Off => Off
ignore_repeated_source => Off => Off
ignore_user_abort => Off => Off
implicit_flush => On => On
include_path => .:/usr/local/lsws/lsphp74/share/pear:/usr/local/lsws/lsphp74/share/php => .:/usr/local/lsws/lsphp74/share/pear:/usr/local/lsws/lsphp74/share/php
input_encoding => no value => no value
internal_encoding => no value => no value
log_errors => On => On
log_errors_max_len => 1024 => 1024
mail.add_x_header => Off => Off
mail.force_extra_parameters => no value => no value
mail.log => no value => no value
max_execution_time => 0 => 0
max_file_uploads => 20 => 20
max_input_nesting_level => 64 => 64
max_input_time => -1 => -1
max_input_vars => 1000 => 1000
memory_limit => 512M => 512M
open_basedir => no value => no value
output_buffering => 0 => 0
output_encoding => no value => no value
output_handler => no value => no value
post_max_size => 8M => 8M
precision => 14 => 14
realpath_cache_size => 4096K => 4096K
realpath_cache_ttl => 120 => 120
register_argc_argv => On => On
report_memleaks => On => On
report_zend_debug => Off => Off
request_order => GP => GP
sendmail_from => no value => no value
sendmail_path => /usr/sbin/sendmail -t -i => /usr/sbin/sendmail -t -i
serialize_precision => -1 => -1
short_open_tag => Off => Off
SMTP => localhost => localhost
smtp_port => 25 => 25
sys_temp_dir => no value => no value
syslog.facility => LOG_USER => LOG_USER
syslog.filter => no-ctrl => no-ctrl
syslog.ident => php => php
track_errors => Off => Off
unserialize_callback_func => no value => no value
upload_max_filesize => 100M => 100M
upload_tmp_dir => no value => no value
user_dir => no value => no value
user_ini.cache_ttl => 300 => 300
user_ini.filename => .user.ini => .user.ini
variables_order => GPCS => GPCS
xmlrpc_error_number => 0 => 0
xmlrpc_errors => Off => Off
zend.assertions => -1 => -1
zend.detect_unicode => On => On
zend.enable_gc => On => On
zend.exception_ignore_args => On => On
zend.multibyte => Off => Off
zend.script_encoding => no value => no value
zend.signal_check => Off => Off
ctype
ctype functions => enabled
curl
cURL support => enabled
cURL Information => 7.29.0
Age => 3
Features
AsynchDNS => Yes
CharConv => No
Debug => No
GSS-Negotiate => Yes
IDN => Yes
IPv6 => Yes
krb4 => No
Largefile => Yes
libz => Yes
NTLM => Yes
NTLMWB => Yes
SPNEGO => No
SSL => Yes
SSPI => No
TLS-SRP => No
Protocols => dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtsp, scp, sftp, smtp, smtps, telnet, tftp
Host => x86_64-redhat-linux-gnu
SSL Version => NSS/3.53.1
ZLib Version => 1.2.7
libSSH Version => libssh2/1.8.0
curl.cainfo => no value => no value
date
date/time support => enabled
timelib version => 2018.04
"Olson" Timezone Database Version => 2021.5
Timezone Database => internal
Default timezone => America/Phoenix
date.default_latitude => 31.7667 => 31.7667
date.default_longitude => 35.2333 => 35.2333
date.sunrise_zenith => 90.583333 => 90.583333
date.sunset_zenith => 90.583333 => 90.583333
date.timezone => America/Phoenix => America/Phoenix
dom
DOM/XML => enabled
DOM/XML API Version => 20031129
libxml Version => 2.9.1
HTML Support => enabled
XPath Support => enabled
XPointer Support => enabled
Schema Support => enabled
RelaxNG Support => enabled
exif
EXIF Support => enabled
Supported EXIF Version => 0220
Supported filetypes => JPEG, TIFF
Multibyte decoding support using mbstring => enabled
Extended EXIF tag formats => Canon, Casio, Fujifilm, Nikon, Olympus, Samsung, Panasonic, DJI, Sony, Pentax, Minolta, Sigma, Foveon, Kyocera, Ricoh, AGFA, Epson
exif.decode_jis_intel => JIS => JIS
exif.decode_jis_motorola => JIS => JIS
exif.decode_unicode_intel => UCS-2LE => UCS-2LE
exif.decode_unicode_motorola => UCS-2BE => UCS-2BE
exif.encode_jis => no value => no value
exif.encode_unicode => ISO-8859-15 => ISO-8859-15
fileinfo
fileinfo support => enabled
libmagic => 537
filter
Input Validation and Filtering => enabled
filter.default => unsafe_raw => unsafe_raw
filter.default_flags => no value => no value
ftp
FTP support => enabled
FTPS support => enabled
gd
GD Support => enabled
GD Version => bundled (2.1.0 compatible)
FreeType Support => enabled
FreeType Linkage => with freetype
FreeType Version => 2.8.0
GIF Read Support => enabled
GIF Create Support => enabled
JPEG Support => enabled
libJPEG Version => 6b
PNG Support => enabled
libPNG Version => 1.5.13
WBMP Support => enabled
XPM Support => enabled
libXpm Version => 30411
XBM Support => enabled
WebP Support => enabled
TGA Read Support => enabled
gd.jpeg_ignore_warning => 1 => 1
gettext
GetText Support => enabled
hash
hash support => enabled
Hashing Engines => md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b crc32c fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support => Enabled
MHASH API Version => Emulated Support
iconv
iconv support => enabled
iconv implementation => glibc
iconv library version => 2.17
iconv.input_encoding => no value => no value
iconv.internal_encoding => no value => no value
iconv.output_encoding => no value => no value
igbinary
igbinary support => enabled
igbinary version => 3.0.1
igbinary APCu serializer ABI => 0
igbinary session support => yes
igbinary.compact_strings => On => On
imap
IMAP c-Client Version => 2007f
SSL Support => enabled
Kerberos Support => enabled
imap.enable_insecure_rsh => Off => Off
intl
Internationalization support => enabled
ICU version => 50.2
ICU Data version => 50.2
ICU TZData version => 2018e
ICU Unicode version => 6.2
intl.default_locale => no value => no value
intl.error_level => 0 => 0
intl.use_exceptions => 0 => 0
json
json support => enabled
libxml
libXML support => active
libXML Compiled Version => 2.9.1
libXML Loaded Version => 20901
libXML streams => enabled
mbstring
Multibyte Support => enabled
Multibyte string engine => libmbfl
HTTP input encoding translation => disabled
libmbfl version => 1.3.2
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support => enabled
Multibyte regex (oniguruma) version => 6.8.2
mbstring.detect_order => no value => no value
mbstring.encoding_translation => Off => Off
mbstring.func_overload => 0 => 0
mbstring.http_input => no value => no value
mbstring.http_output => no value => no value
mbstring.http_output_conv_mimetypes => text/|application/xhtml+xml => text/|application/xhtml+xml
mbstring.internal_encoding => no value => no value
mbstring.language => neutral => neutral
mbstring.regex_retry_limit => 1000000 => 1000000
mbstring.regex_stack_limit => 100000 => 100000
mbstring.strict_detection => Off => Off
mbstring.substitute_character => no value => no value
mcrypt
mcrypt support => enabled
mcrypt_filter support => enabled
Version => 2.5.8
Api No => 20021217
Supported ciphers => cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes => cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir => no value => no value
mcrypt.modes_dir => no value => no value
mysqli
MysqlI Support => enabled
Client API library version => mysqlnd 7.4.28
Active Persistent Links => 0
Inactive Persistent Links => 0
Active Links => 0
mysqli.allow_local_infile => Off => Off
mysqli.allow_persistent => On => On
mysqli.default_host => no value => no value
mysqli.default_port => 3306 => 3306
mysqli.default_pw => no value => no value
mysqli.default_socket => /tmp/mysql.sock => /tmp/mysql.sock
mysqli.default_user => no value => no value
mysqli.max_links => Unlimited => Unlimited
mysqli.max_persistent => Unlimited => Unlimited
mysqli.reconnect => Off => Off
mysqli.rollback_on_cached_plink => Off => Off
mysqlnd
mysqlnd => enabled
Version => mysqlnd 7.4.28
Compression => supported
core SSL => supported
extended SSL => supported
Command buffer size => 4096
Read buffer size => 32768
Read timeout => 86400
Collecting statistics => Yes
Collecting memory statistics => No
Tracing => n/a
Loaded plugins => mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_caching_sha2_password,auth_plugin_sha256_password
API Extensions => mysqli,pdo_mysql
openssl
OpenSSL support => enabled
OpenSSL Library Version => OpenSSL 1.0.2k-fips 26 Jan 2017
OpenSSL Header Version => OpenSSL 1.0.2k 26 Jan 2017
Openssl default config => /etc/pki/tls/openssl.cnf
openssl.cafile => no value => no value
openssl.capath => no value => no value
pcntl
pcntl support => enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support => enabled
PCRE Library Version => 10.35 2020-05-09
PCRE Unicode Version => 13.0.0
PCRE JIT Support => enabled
PCRE JIT Target => x86 64bit (little endian + unaligned)
pcre.backtrack_limit => 1000000 => 1000000
pcre.jit => 0 => 0
pcre.recursion_limit => 100000 => 100000
PDO
PDO support => enabled
PDO drivers => mysql, sqlite
pdo_mysql
PDO Driver for MySQL => enabled
Client API version => mysqlnd 7.4.28
pdo_mysql.default_socket => /tmp/mysql.sock => /tmp/mysql.sock
pdo_sqlite
PDO Driver for SQLite 3.x => enabled
SQLite Library => 3.7.17
Phar
Phar: PHP Archive support => enabled
Phar API version => 1.1.1
Phar-based phar archives => enabled
Tar-based phar archives => enabled
ZIP-based phar archives => enabled
gzip compression => enabled
bzip2 compression => enabled
Native OpenSSL support => enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list => no value => no value
phar.readonly => On => On
phar.require_hash => On => On
posix
POSIX support => enabled
readline
Readline Support => enabled
Readline library => EditLine wrapper
cli.pager => no value => no value
cli.prompt => \b > => \b >
redis
Redis Support => enabled
Redis Version => 5.1.1
Available serializers => php, json, igbinary
Available compression => lzf
redis.arrays.algorithm => no value => no value
redis.arrays.auth => no value => no value
redis.arrays.autorehash => 0 => 0
redis.arrays.connecttimeout => 0 => 0
redis.arrays.consistent => 0 => 0
redis.arrays.distributor => no value => no value
redis.arrays.functions => no value => no value
redis.arrays.hosts => no value => no value
redis.arrays.index => 0 => 0
redis.arrays.lazyconnect => 0 => 0
redis.arrays.names => no value => no value
redis.arrays.pconnect => 0 => 0
redis.arrays.previous => no value => no value
redis.arrays.readtimeout => 0 => 0
redis.arrays.retryinterval => 0 => 0
redis.clusters.auth => no value => no value
redis.clusters.cache_slots => 0 => 0
redis.clusters.persistent => 0 => 0
redis.clusters.read_timeout => 0 => 0
redis.clusters.seeds => no value => no value
redis.clusters.timeout => 0 => 0
redis.pconnect.connection_limit => 0 => 0
redis.pconnect.pooling_enabled => 1 => 1
redis.session.lock_expire => 0 => 0
redis.session.lock_retries => 10 => 10
redis.session.lock_wait_time => 2000 => 2000
redis.session.locking_enabled => 0 => 0
Reflection
Reflection => enabled
session
Session Support => enabled
Registered save handlers => files user redis rediscluster
Registered serializer handlers => php_serialize php php_binary igbinary
session.auto_start => Off => Off
session.cache_expire => 180 => 180
session.cache_limiter => nocache => nocache
session.cookie_domain => no value => no value
session.cookie_httponly => no value => no value
session.cookie_lifetime => 0 => 0
session.cookie_path => / => /
session.cookie_samesite => no value => no value
session.cookie_secure => 0 => 0
session.gc_divisor => 1000 => 1000
session.gc_maxlifetime => 1440 => 1440
session.gc_probability => 1 => 1
session.lazy_write => On => On
session.name => PHPSESSID => PHPSESSID
session.referer_check => no value => no value
session.save_handler => redis => redis
session.save_path => tcp://127.0.0.1:6379 => tcp://127.0.0.1:6379
session.serialize_handler => php => php
session.sid_bits_per_character => 5 => 5
session.sid_length => 26 => 26
session.upload_progress.cleanup => On => On
session.upload_progress.enabled => On => On
session.upload_progress.freq => 1% => 1%
session.upload_progress.min_freq => 1 => 1
session.upload_progress.name => PHP_SESSION_UPLOAD_PROGRESS => PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix => upload_progress_ => upload_progress_
session.use_cookies => 1 => 1
session.use_only_cookies => 1 => 1
session.use_strict_mode => 0 => 0
session.use_trans_sid => 0 => 0
shmop
shmop support => enabled
SimpleXML
SimpleXML support => enabled
Schema support => enabled
sockets
Sockets Support => enabled
SPL
SPL support => enabled
Interfaces => OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes => AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
sqlite3
SQLite3 support => enabled
sqlite3.extension_dir => no value => no value
standard
Dynamic Library Support => enabled
Path to sendmail => /usr/sbin/sendmail -t -i
assert.active => 1 => 1
assert.bail => 0 => 0
assert.callback => no value => no value
assert.exception => 0 => 0
assert.quiet_eval => 0 => 0
assert.warning => 1 => 1
auto_detect_line_endings => 0 => 0
default_socket_timeout => 60 => 60
session.trans_sid_hosts => no value => no value
session.trans_sid_tags => a=href,area=href,frame=src,form= => a=href,area=href,frame=src,form=
unserialize_max_depth => 4096 => 4096
url_rewriter.hosts => no value => no value
url_rewriter.tags => form= => form=
user_agent => no value => no value
sysvmsg
sysvmsg support => enabled
sysvsem
sysvsem support => enabled
sysvshm
sysvshm support => enabled
tokenizer
Tokenizer Support => enabled
xml
XML Support => active
XML Namespace Support => active
libxml2 Version => 2.9.1
xmlreader
XMLReader => enabled
xmlwriter
XMLWriter => enabled
xsl
XSL => enabled
libxslt Version => 1.1.28
libxslt compiled against libxml Version => 2.9.1
EXSLT => enabled
libexslt Version => 1.1.28
Zend OPcache
Opcode Caching => Disabled
Optimization => Disabled
SHM Cache => Enabled
File Cache => Disabled
Startup Failed => Opcode Caching is disabled for CLI
opcache.blacklist_filename => /etc/php.d/opcache.blacklist => /etc/php.d/opcache.blacklist
opcache.consistency_checks => 0 => 0
opcache.dups_fix => Off => Off
opcache.enable => On => On
opcache.enable_cli => Off => Off
opcache.enable_file_override => Off => Off
opcache.error_log => no value => no value
opcache.file_cache => no value => no value
opcache.file_cache_consistency_checks => On => On
opcache.file_cache_only => Off => Off
opcache.file_update_protection => 2 => 2
opcache.force_restart_timeout => 180 => 180
opcache.huge_code_pages => Off => Off
opcache.interned_strings_buffer => 8 => 8
opcache.lockfile_path => /tmp => /tmp
opcache.log_verbosity_level => 1 => 1
opcache.max_accelerated_files => 4000 => 4000
opcache.max_file_size => 0 => 0
opcache.max_wasted_percentage => 5 => 5
opcache.memory_consumption => 32 => 32
opcache.opt_debug_level => 0 => 0
opcache.optimization_level => 0x7FFEBFFF => 0x7FFEBFFF
opcache.preferred_memory_model => no value => no value
opcache.preload => no value => no value
opcache.preload_user => no value => no value
opcache.protect_memory => Off => Off
opcache.restrict_api => no value => no value
opcache.revalidate_freq => 2 => 2
opcache.revalidate_path => Off => Off
opcache.save_comments => On => On
opcache.use_cwd => On => On
opcache.validate_permission => Off => Off
opcache.validate_root => Off => Off
opcache.validate_timestamps => On => On
zip
Zip => enabled
Zip version => 1.15.6
Libzip headers version => 1.5.2
Libzip library version => 1.5.2
zlib
ZLib Support => enabled
Stream Wrapper => compress.zlib://
Stream Filter => zlib.inflate, zlib.deflate
Compiled Version => 1.2.7
Linked Version => 1.2.7
zlib.output_compression => Off => Off
zlib.output_compression_level => -1 => -1
zlib.output_handler => no value => no value
Additional Modules
Module Name
Environment
Variable => Value
VIRTUAL_ENV => /www/server/panel/pyenv
PATH => /www/server/panel/pyenv/bin:/www/server/panel/pyenv/bin:/www/server/panel/pyenv/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
BT_TASK => 1
_ => /usr/local/lsws/lsphp74/bin/php
PWD => /www/server/panel
LANG => en_US.UTF-8
SHLVL => 6
PHP Variables
Variable => Value
$SERVER['VIRTUAL_ENV'] => /www/server/panel/pyenv
$SERVER['PATH'] => /www/server/panel/pyenv/bin:/www/server/panel/pyenv/bin:/www/server/panel/pyenv/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
$SERVER['BT_TASK'] => 1
$SERVER[''] => /usr/local/lsws/lsphp74/bin/php
$SERVER['PWD'] => /www/server/panel
$SERVER['LANG'] => en_US.UTF-8
$SERVER['SHLVL'] => 6
$SERVER['PHP_SELF'] =>
$SERVER['SCRIPT_NAME'] =>
$SERVER['SCRIPT_FILENAME'] =>
$SERVER['PATH_TRANSLATED'] =>
$SERVER['DOCUMENT_ROOT'] =>
$SERVER['REQUEST_TIME_FLOAT'] => 1658129852.7897
$SERVER['REQUEST_TIME'] => 1658129852
$SERVER['argv'] => Array
$_SERVER['argc'] => 0
PHP License
This program is free software; you can redistribute it and/or modify
it under the terms of the PHP License as published by the PHP Group
and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any
questions about PHP licensing, please contact license@php.net.
