Hi! First, I want to thank you for your work and panel. It does a good job.
But I am faced with one issue. the cron is working, but the minimum time is 5-6 minutes, even the task is set to do tasks every 1, 2, 3... minutes
Where is the place to reconfigure the minimum task time or the cron at all
Sys:
Centos 7 - updated
fixed was started
cron, it seems, is working, but the exact execution is only on 5-6 minutes as a minimum
https://prnt.sc/v5jLiBPOvgXo
